Is Buck Mtn down? I have not had a connection for about a day. The K7DK UHF repeater is still operating. 73, Dave
Thanks for the report. The site is clearly not totally down but there does appear to be some issue to investigate. Will report back to this thread once we have had a chance to do so. -Doug- HamWAN Netops On Fri, Sep 9, 2022 at 9:08 AM David C. Jenner via PSDR <psdr@hamwan.org> wrote:
73, Dave _______________________________________________ PSDR mailing list PSDR@hamwan.org http://mail.hamwan.net/mailman/listinfo/psdr
David, It appears only the sector (the radio clients connect to) is down, the rest of the site seem OK. I am not able to access it via any of the normal methods right now, which means a site visit is probably needed. We have not been able to access the site for over two years now due to COVID and other issues. I'll reach out to our site contact and see if we can schedule something before the weather turns this fall. Thanks Kenny On Fri, Sep 9, 2022 at 9:58 AM Doug Kingston <dpk@randomnotes.org> wrote:
The sector went offline yesterday (Thur 8th) at about 10am. On Fri, Sep 9, 2022 at 10:06 AM Kenny Richards <richark@gmail.com> wrote:
David,
Thanks Kenny
Kenny, Let me know what you find out for doing a site visit – there’s a lot up there that needs to be looked at and cleaned up. Some Gold references to be cleaned up and documentation/DNS to be updated, label the R1 port that S2 is using/etc. Rob From: PSDR [mailto:psdr-bounces@hamwan.org] On Behalf Of Kenny Richards Sent: Friday, September 9, 2022 10:07 AM To: Puget Sound Data Ring Subject: Re: [HamWAN PSDR] Buck Mountain Down? David, It appears only the sector (the radio clients connect to) is down, the rest of the site seem OK. I am not able to access it via any of the normal methods right now, which means a site visit is probably needed. We have not been able to access the site for over two years now due to COVID and other issues. I'll reach out to our site contact and see if we can schedule something before the weather turns this fall. Thanks Kenny On Fri, Sep 9, 2022 at 9:58 AM Doug Kingston <dpk@randomnotes.org> wrote: Thanks for the report. The site is clearly not totally down but there does appear to be some issue to investigate. Will report back to this thread once we have had a chance to do so. -Doug- HamWAN Netops On Fri, Sep 9, 2022 at 9:08 AM David C. Jenner via PSDR <psdr@hamwan.org> wrote: Is Buck Mtn down? I have not had a connection for about a day. The K7DK UHF repeater is still operating. 73, Dave _______________________________________________ PSDR mailing list PSDR@hamwan.org http://mail.hamwan.net/mailman/listinfo/psdr _______________________________________________ PSDR mailing list PSDR@hamwan.org http://mail.hamwan.net/mailman/listinfo/psdr
Recall that I am 1.69 miles line of sight from the location and can perhaps lend a hand if needed. I have scheduling constraints, but maybe could help out. 73, Dave K7DCJ
On Sep 9, 2022, at 4:59 PM, Rob Salsgiver <rob@nr3o.com> wrote:
Kenny,
Rob
David,
Thanks Kenny
73, Dave _______________________________________________ PSDR mailing list PSDR@hamwan.org http://mail.hamwan.net/mailman/listinfo/psdr _______________________________________________ PSDR mailing list PSDR@hamwan.org http://mail.hamwan.net/mailman/listinfo/psdr _______________________________________________ PSDR mailing list PSDR@hamwan.org http://mail.hamwan.net/mailman/listinfo/psdr
Just following up, the Buck site is back online now. Some work was done the previous week at the site and moved around some things. After ensuring everything was plugged and power cycling the sector, it came back. While onsite, we also replaced the R1 router and cleaned up things, the new router provides POE control for the sector/PtP radios. Rob and I spent a while doing site planning for re-directing the old Gold PtP next spring, which will add redundant paths to the site again and maybe use it as a jump off point for another. Thanks Kenny On Fri, Sep 9, 2022 at 5:26 PM David Jenner via PSDR <psdr@hamwan.org> wrote:
73, Dave K7DCJ
Kenny,
Rob
*From:* PSDR [mailto:psdr-bounces@hamwan.org] *On Behalf Of *Kenny Richards *Sent:* Friday, September 9, 2022 10:07 AM *To:* Puget Sound Data Ring *Subject:* Re: [HamWAN PSDR] Buck Mountain Down?
David,
Thanks
Kenny
-Doug-
HamWAN Netops
Thanks Kenny and Rob! -Doug- On Fri, Sep 16, 2022 at 6:51 PM Kenny Richards <richark@gmail.com> wrote:
Thanks Kenny
73, Dave K7DCJ
Kenny,
Rob
David,
Thanks
Kenny
-Doug-
HamWAN Netops
Thanks all. I’m back up here in West Seattle. Looking at 3.42 down and 3.98 up 65 msec ping at idle and no packet loss here. Ronald (Ron) Zuber N4RDZ/WQTA-849 SHARES NNA0RZ 3711 SW Morgan St Seattle, WA 98126 Cell 206-423-0602 HamShack Hotline #12111 Email: n4rdz.va@gmail.com <mailto:n4rdz.va@gmail.com> What3words ///neon.spit.worm From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Doug Kingston Sent: Friday, September 16, 2022 7:52 PM To: Puget Sound Data Ring <psdr@hamwan.org> Subject: Re: [HamWAN PSDR] Buck Mountain Down? Thanks Kenny and Rob! -Doug- On Fri, Sep 16, 2022 at 6:51 PM Kenny Richards <richark@gmail.com <mailto:richark@gmail.com> > wrote: Just following up, the Buck site is back online now. Some work was done the previous week at the site and moved around some things. After ensuring everything was plugged and power cycling the sector, it came back. While onsite, we also replaced the R1 router and cleaned up things, the new router provides POE control for the sector/PtP radios. Rob and I spent a while doing site planning for re-directing the old Gold PtP next spring, which will add redundant paths to the site again and maybe use it as a jump off point for another. Thanks Kenny On Fri, Sep 9, 2022 at 5:26 PM David Jenner via PSDR <psdr@hamwan.org <mailto:psdr@hamwan.org> > wrote: Recall that I am 1.69 miles line of sight from the location and can perhaps lend a hand if needed. I have scheduling constraints, but maybe could help out. 73, Dave K7DCJ On Sep 9, 2022, at 4:59 PM, Rob Salsgiver <rob@nr3o.com <mailto:rob@nr3o.com> > wrote: Kenny, Let me know what you find out for doing a site visit – there’s a lot up there that needs to be looked at and cleaned up. Some Gold references to be cleaned up and documentation/DNS to be updated, label the R1 port that S2 is using/etc. Rob From: PSDR [mailto:psdr-bounces@hamwan.org <mailto:psdr-bounces@hamwan.org> ] On Behalf Of Kenny Richards Sent: Friday, September 9, 2022 10:07 AM To: Puget Sound Data Ring Subject: Re: [HamWAN PSDR] Buck Mountain Down? David, It appears only the sector (the radio clients connect to) is down, the rest of the site seem OK. I am not able to access it via any of the normal methods right now, which means a site visit is probably needed. We have not been able to access the site for over two years now due to COVID and other issues. I'll reach out to our site contact and see if we can schedule something before the weather turns this fall. Thanks Kenny On Fri, Sep 9, 2022 at 9:58 AM Doug Kingston <dpk@randomnotes.org <mailto:dpk@randomnotes.org> > wrote: Thanks for the report. The site is clearly not totally down but there does appear to be some issue to investigate. Will report back to this thread once we have had a chance to do so. -Doug- HamWAN Netops On Fri, Sep 9, 2022 at 9:08 AM David C. Jenner via PSDR <psdr@hamwan.org <mailto:psdr@hamwan.org> > wrote: Is Buck Mtn down? I have not had a connection for about a day. The K7DK UHF repeater is still operating. 73, Dave _______________________________________________ PSDR mailing list PSDR@hamwan.org <mailto:PSDR@hamwan.org> http://mail.hamwan.net/mailman/listinfo/psdr _______________________________________________ PSDR mailing list PSDR@hamwan.org <mailto:PSDR@hamwan.org> http://mail.hamwan.net/mailman/listinfo/psdr _______________________________________________ PSDR mailing list PSDR@hamwan.org <mailto:PSDR@hamwan.org> http://mail.hamwan.net/mailman/listinfo/psdr _______________________________________________ PSDR mailing list PSDR@hamwan.org <mailto:PSDR@hamwan.org> http://mail.hamwan.net/mailman/listinfo/psdr _______________________________________________ PSDR mailing list PSDR@hamwan.org <mailto:PSDR@hamwan.org> http://mail.hamwan.net/mailman/listinfo/psdr
participants (6)
David C. Jenner -
David Jenner -
Doug Kingston -
Kenny Richards -
n4rdz.va@gmail.com -
Rob Salsgiver
