I notice that you specify only Mikrotik router/modem products. Is this the only manufacturer that makes a product that works with your network. Does Ubiquiti make a product that would work? Or anyone else? It seems it would be prudish to not depend on one manufacturer. *73 Doug* *WA3DSP* *http://www.crompton.com/hamradio <http://www.crompton.com/hamradio>*
The NV2 protocol is a proprietary over the air protocol, and only Mikrotik supports it. This is just the AP to end user interface, it still spits out Ethernet and IP. Simply put there's no other products which work out of band and meet 100-150 USD price point. Should something better come along, it can be replaced, and still deliver the same IP/IPv6 transport.
I'm not a prude. -- Bryan Fields 727-409-1194 - Voice http://bryanfields.net
Doug, The short answer to your question, is yes, Mikrotik is the only compatible manufacturer. The long answer is that standard wifi protocols face a number of challenges in the long range and complex environment posed in a network like ours (timing limits, hidden nodes, etc). There are specialized protocols that better handle those challenges. At the time we were selecting what hardware we were going to work with, the options that made sense were Mikrotik’s NV2 protocol, or Ubiquiti’s AirMax protocol. Both of which are proprietary and would have locked us into the single vendor setup we have now. We chose to go with Mikrotik because their modems were capable of significantly more flexibility in the routing and configuration than the Ubiquiti modems were at the time. So yes, it is only a single vendor that is compatible over the air. The choice was made for technical reasons that haven’t changed in the interim, as much as we’d like to have the option for a vendor agnostic protocol, it isn’t really available to us. As was noted separately, the modem is in theory a fairly small part of your setup. You can put whatever devices you like plugged into the ethernet side, and work as normal. Just the RF part itself requires a Mikrotik radio. Thanks, Nigel
73 Doug WA3DSP http://www.crompton.com/hamradio <http://www.crompton.com/hamradio> _______________________________________________ PSDR mailing list PSDR@hamwan.org http://mail.hamwan.net/mailman/listinfo/psdr
Nigel, Thanks for the nice explanation. It makes sense but it is a shame there is only one source. It is kind of scary depending on one company for the RF system but I guess that is the way it must be, *73 Doug* *WA3DSP* *http://www.crompton.com/hamradio <http://www.crompton.com/hamradio>* On Sun, Dec 6, 2020 at 12:24 AM Nigel Vander Houwen <nigel@nigelvh.com> wrote:
Doug,
Thanks, Nigel
*73 Doug*
*WA3DSP*
*http://www.crompton.com/hamradio <http://www.crompton.com/hamradio>* _______________________________________________ PSDR mailing list PSDR@hamwan.org http://mail.hamwan.net/mailman/listinfo/psdr
Bryan Fields -
Doug Crompton -
Nigel Vander Houwen
